Cylinder 6 misfire
Old May 18, 2009 | 10:58 PM
mcss8541's Avatar
mcss8541
Unhappy Cylinder 6 misfire
Hey everyone got a quick question for ya. I have been having a noticeable miss at the #6 cyl and the CEL proved it. The engine will smooth out after it has been running however on cold starts or even if I'm going in reverse you can really feel it. Now outside of fuel injector, spark plug ( brand new ), wires ( brand new ), coil ( brand new ), cap and rotor ( relatively new ), pickup coil ( brand new ), crank position sensor ( brand new ), and compression. is there any where else I should be looking. I will be pulling injectors this weekend and fuel rail. Thanks!
Old May 19, 2009 | 09:40 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Did you check in injector plug to insure there isn't a loose/broken wire?
Old May 19, 2009 | 12:08 PM
mcss8541's Avatar
mcss8541
No sir but will do. It's mind boggeling because once it's warmed and running for awhile you barely notice the miss in it.
