A/C Cruise Control and Radio all dead
Old May 20, 2009 | 12:18 PM
emcee's Avatar
emcee
Default A/C Cruise Control and Radio all dead
None of these things show any life at all. No lights, nothing. Before I start looking around is there anything these all have in common? I checked the fuse for the radio and it's good. Couldn't find fuses for the others.
Old May 20, 2009 | 12:52 PM
Steel Horse's Avatar
Steel Horse
check the fuse box, in the cab and under the hood..also check your relays
Old May 20, 2009 | 01:14 PM
emcee's Avatar
emcee
I checked the radio fuse and it's good. I will swap the A/C relay with another working relay and check that. Didn't see any relays or fuses for the cruise.
Old May 20, 2009 | 02:24 PM
Steel Horse
what kinda truck are you driving
Old May 20, 2009 | 02:34 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Everything is where is should be correct? No holes in the a/c lines? It might need to be recharged.
Old May 20, 2009 | 02:45 PM
zman17's Avatar
zman17
Retired Moderator - RIP
There is something they have in common, the PDC and the wire harness.
Old May 20, 2009 | 02:53 PM
emcee's Avatar
emcee
96 Ram 1500 Laramie SLT 2dr Regular Cab 4WD LB
