rtv dry time?
Old May 21, 2009 | 11:55 PM
wesley11's Avatar
wesley11
Default rtv dry time?
I just replaced my water pump and was wondering how long I should wait before adding coolant to the system. Does the rtv need time time dry> Thanks for any help
Old May 22, 2009 | 01:14 AM
speeddemon31176's Avatar
speeddemon31176
Add away. The rtv will seal the system as soon as you install the pump. The only thing it will do from there is cure. Don't worry about drying time. Your fine.
Old May 22, 2009 | 01:31 AM
jasonw's Avatar
jasonw
Site Moderator
If you look on the back of the RTV tube, it usually tells you the dry time. RTV Black says one hour to set, and then about 12 hours (or 24, can't recall exactly) to fully cure, depending on air temperature.
After an hour, you should be fine to add coolant I'd say, but I wouldn't run the truck anywhere until its fully (or very close to fully) cured.
Old May 22, 2009 | 01:55 AM
Laramie1997's Avatar
Laramie1997
Usually best to let that goop cure over night just to be on the safe side.
Old May 22, 2009 | 02:49 AM
iwhitne's Avatar
iwhitne
I just did my font/rear diffs.. I applied it.. and installed the part immediatly.. then wait 2 hours before adding in my gear oil.. no leaks so far!
Old May 22, 2009 | 01:24 PM
J415's Avatar
J415
2 hours is a good time to wait. I always let it dry for 24 hours before adding any fluid. I figure, whats the hurry. If you don't wait enough, then you have to do it again.
