temp question
Old May 27, 2009 | 11:48 PM
wesley11's Avatar
wesley11
I will flush out the radiator tommorow. Should I buy the prestone flush or just put a hose in the cap? I have heard that the flushes can clog the heater core. Thanks again for the help.
Old May 27, 2009 | 11:59 PM
dodge15004x45.9's Avatar
dodge15004x45.9
My truck mechanic told me to stick a garden hoes down in there.
Old May 28, 2009 | 12:17 AM
wesley11's Avatar
wesley11
Thanks. I will update tommorrow when finished.
Old May 28, 2009 | 02:31 AM
J415's Avatar
J415
If you think the radiator is clogged and you want to dislodge it, it would be wise of you to just flush and reverse flush the radiator instead of doing the whole system. That way, if you do dislodge it, that junk won't be introduced to the rest of your cooling system. On a side note, I've heard of people using CLR to flush there system. Good luck. Keep us posted.
Old May 28, 2009 | 03:06 AM
dodge15004x45.9
"it would be wise of you to just flush and reverse flush the radiator instead of doing the whole system."
Explain I plan on doing my t stat this weekend and the plugs....
Old May 28, 2009 | 08:44 PM
J415's Avatar
J415
What part confuses you? I'm just asking so I can answer whatever question you have.
Old May 28, 2009 | 08:54 PM
Laramie1997's Avatar
Laramie1997
Check your fan clutch. The surging issue can be caused by a failing clutch.
Old May 29, 2009 | 12:23 AM
wesley11's Avatar
wesley11
Red face
I replaced the fan clutch when I did the water pump. Wouldnt be the t stat would it? I didnt replace that.
Old May 29, 2009 | 01:19 AM
dodge15004x45.9
Might as well there like 6 bucks.
Old May 29, 2009 | 01:23 AM
Laramie1997
Not usually, Those either fail closed causing you over heat. Unless you installed a fail safe which in case of a problem, will fail in the open position.
