behind grille lights
Old May 28, 2009 | 12:19 PM
01dabram20's Avatar
01dabram20
Default behind grille lights
I have some daylighters that i have had since jan. well i want to put them behind the grille but don't know how to attach them with the passager side being the hardest to do because of the lines. Can anybody with lights behind the grille take some pics of your set up with the grille up so i can see how to mount them? Thanks!
Old May 28, 2009 | 01:06 PM
dakotas ram's Avatar
dakotas ram
heres one pic.....there was a thread on here awhile ago that was better, but i cant find it
https://dodgeforum.com/forum/2nd-gen...56k-die-2.html
Old May 28, 2009 | 01:15 PM
dakotas ram
check out pg 7
https://dodgeforum.com/forum/2nd-gen...-lights-7.html
Old May 28, 2009 | 03:39 PM
PurplDodge's Avatar
PurplDodge
I dont believe that the daylighters will fit. The Reflector casing is too large. Slimlites or Hella 500s would fit better.
Old May 30, 2009 | 09:44 PM
Gord.'s Avatar
Gord.
I dont have any pics, but I have some 4.5 inch lights behind my grille. I just drilled into the side of the rad support and bolted them in.
Gord.
Old May 30, 2009 | 10:22 PM
01dabram20's Avatar
01dabram20
well i have a 01 dodge and the front setup behind the grille is different from 95-97 i think. So i don't know if i have to reroute my ac lines so i can fit lights there.
Old May 30, 2009 | 10:28 PM
Gord.'s Avatar
Gord.
Not sure if they changed the setup, but I have .5"-1" of clearance around the pass. side light.
Gord.
