coil spring experiment
Old Jun 3, 2009 | 01:12 AM
btucker's Avatar
btucker
Default coil spring experiment
I am wondering if i could put 3/4 ton coil springs on my 1500 to give it a little more lift? Anyone have any input about this?
Old Jun 3, 2009 | 01:34 AM
Laramie1997's Avatar
Laramie1997
Yes you can. There are a good number of threads on this. Find them with a search.
Old Jun 3, 2009 | 03:23 AM
helms's Avatar
helms
they give you about 3" of lift, olyelr is the one to talk to about this.
Old Jun 3, 2009 | 05:18 AM
jagass's Avatar
jagass
Yeah, you can...Go do it...
Old Jun 3, 2009 | 07:35 AM
olyelr's Avatar
olyelr
Yeppers, it's a direct swap. 3/4 ton V8 springs will net about 2" or so of lift, while the V10 and deisel coils will be a little more (I gained just over 3" with mine).
But, you will also get the same ride quality of a 3/4-1 ton truck (possibly even worse with a reg. cab shortbox like me)
The rear springs are not interchangable, as the 3/4 tons are 3" wide while the half tons are 2.5" wide. Some add-a-leafs will level it off well.
Old Jun 3, 2009 | 11:24 AM
PurplDodge's Avatar
PurplDodge
Or you could use Off-Road coils and springs.
Old Jun 3, 2009 | 12:31 PM
dsertdog56's Avatar
dsertdog56
Off road coils will only net you about an inch and a half. Plus they're not easy to find. The rear springs will give you about 2 inches, but you'd be better off with a AAL. I recommend the BDS leaf as that setup gives you about 3 inches.
Old Jun 3, 2009 | 12:43 PM
Cereal Killer's Avatar
Cereal Killer
Maybe because it says 4x4 next to his name...
Old Jun 3, 2009 | 12:56 PM
dsertdog56's Avatar
dsertdog56
I can't read....I thought it said 2wd....er 5.2...I'm going back to work!
Old Jun 3, 2009 | 01:04 PM
PurplDodge's Avatar
PurplDodge
That is what I want, then. I just love the way Off-Road Rams sit.
