Removing the catalytic onverter
Old Jun 4, 2009 | 02:11 AM
rczanstke's Avatar
rczanstke
Default Removing the catalytic onverter
I own a 1996 Ram 1500 4x4 5.2L
I've been thinking about removing the cat from my truck. I remember reading something about it on a different thread here, but I did a search and couldn't find it. (Though I did not search very hard, there was probably something there, I just did not want to look very hard. Sorry for the inconvenience.)
I know there is an O2 sensor, but I couldn't remember if it was before, after, or both. What I want to ask is:
Is it worth the trouble? What would be the effects of this? and is it possible?
I realize that these questions have probably been answered many times before. Again, sorry for asking the same question that has already been answered.
Old Jun 4, 2009 | 02:25 AM
Laramie1997's Avatar
Laramie1997
Some people report getting a MIL light (CEL) I gutted mine a long time ago and never got one.
Your exhaust will be a little louder.
Depending on where your truck was built, you can either have 2 or 4 O2 sensors. Only the trucks shipped for sale in California had 2 cats (4 O2 sensors)
It is very possible, but why are you wanting to do it? Is it clogged up, or are you just wanting somthin to do?
EDIT: some also report a sulfer smell coming from the pipes dir to the lack of the catalyst being there.
You can either remove the whole thing and install a piece of pipe to reconnect it to the rest of your exhaust, or you can cut the old one down and gut it and put it back up.
Old Jun 4, 2009 | 03:15 AM
rczanstke's Avatar
rczanstke
I'm pretty sure that it is clogged.
Old Jun 4, 2009 | 11:29 AM
dakotas ram's Avatar
dakotas ram
you should have a sensor that goes into the front side of the cat and then one behind it.....if you do get a code, you can get a sparkplug nonfouler to move the sensor out of the direct exhaust......be sure to remove the front one b4 ramming anything in there
Old Jun 4, 2009 | 08:20 PM
iwhitne's Avatar
iwhitne
they also sell a "chip" that plugs into the end of your 02 sensor to make the truck think it's running fine
http://www.thefastman.com/02Simms.asp
