Symptoms of too high tranny VB pressure...
Old Jun 8, 2009 | 08:09 AM
aim4squirrels's Avatar
aim4squirrels
Default Symptoms of too high tranny VB pressure...
What are they?
I'm having a slight power engagement delay, most noticeably when the engine is cold, the truck seems to hang a bit high in the RPM's on the shifts, and doesn't drop down into a lower gear on decel when I feel it should.
The truck has felt this way since I put the Sonnax kit in and I'm wondering if I went just a little too far on the VB pressure adjustment screw. I haven't tripped a code or anything, but I just have a sneaking suspicion this might be it.
Also, if MonteC is out there, can I adjust this with an allen wrench without dropping the VB out? I think the nut is accessable, but I know its' right up by the rooster comb and might be a bit tight in there.
Old Jun 8, 2009 | 09:55 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Originally Posted by aim4squirrels
What are they?
These are the same symptoms my truck has had for a while. Does it sometimes slam into gear, from takeoff, if you're not careful?
Old Jun 8, 2009 | 10:08 AM
aim4squirrels
No Slamming, never had that issue. Just hangs a bit and holds a bit too long on Decel. I'm talking a very small amount, just noticeable if you've been driving it a while.
Old Jun 8, 2009 | 06:54 PM
MonteC's Avatar
MonteC
Yes you can adjust the pressure while the VB is still in the transmission. Try it and see what happens. Id also torque the VB bolts (7/16) down to 130inlbs.
