Air bag dashlight help???
Old Jun 17, 2009 | 04:12 PM
AKZEP69's Avatar
AKZEP69
Default Air bag dashlight help???
Got my abs light to stop
suddenly my air bag dashlight comes on sporadically and goes out just as randomly
any ideas where to start would be appreciated!!
Old Jun 17, 2009 | 05:16 PM
99DRAM31887's Avatar
99DRAM31887
check the clockspring in the steering wheel what year is ur truck mines a 97 and my airbag module is in the center of the floorboard under the dash under a cover u might check there u might need to replace something i havent done mine yet my airbag lights on but i was told that was where to start
Old Jun 17, 2009 | 09:26 PM
Ram15002ndGen's Avatar
Ram15002ndGen
Here's a suggestion which may or may not help. I recently bled my brakes (just to clean out the 12 year old brake fluid), and I found that my ABS light blinks on and off much faster when I start the vehicle. Before when I started up the truck, the ABS light would stay on for a bit and go off, now it just blinks so fast I don't hardly see it. Maybe brake fluid pressure may have something to do with your problem. If the pressure being created is erratic, the ABS sensor may kick on, or maybe you have a faulty ABS sensor.
