Look what I found....
First I just want to say thanks to all, without this forum I most likely wouldn't have bought my new/used 1998 Dodge ram 5.2 Quad/longbed
I finally tracked down my serious humming, coming from my rear end. Drained the pumpkin and scooped this out form the bottom
(see pic). Refilled with appropriate oil, still humming. Could this be the reason why I have some serious humming? What is the fix? And how much? I'm novice when it comes to axles and axle parts. Junkyard parts? How can i tell which axle I have?
BTW.. HAPPY FATHERS DAY!
yea...um, i wouldn't be driving with that anymore. next thing you know your rear axle is going to lock up on you going down the road. if i were you, i would get a new set of gears or just get a whole new axle for a easy swap.
do you have an Limited Slip diff ? looks like a normal broken clip.
humming is probably from when it got chewed up, and did a little damage.
drive it another 100,000 and don't worry about it.
That looks like pieces of one of your clutch packs from the limited slip. I can almost bet that it needs a complete rebuild. So if you are good with running an open diff then I wouldnt worry about it.
