Rear Differential Housing Question
Old Jun 22, 2009 | 08:23 AM
peterfromme's Avatar
peterfromme
Default Rear Differential Housing Question
I looked at my rear diff. housing yesterday and noticed that some of it appears "wet", as if it might be leaking fluid. It's not much, just a little. Most of it is on near the bottom and near the UV joint that connects to the drive shaft.
I know this is a difficult question to answer without seeing it, but is some of this normal, or should I be concerned?
I had a Chevy Tahoe that had rear axle problems and it made a noise when I drove so I knew it was bad.
With this truck, I don't notice a noise, just the fluid on the housing.
thanks,
pf
Old Jun 22, 2009 | 08:55 AM
charlie1935's Avatar
charlie1935
Check the lube level. If it looks to be coming out at the flange where the driveshaft attaches it is the pinion seal.
Old Jun 22, 2009 | 09:19 PM
dhvaughan's Avatar
dhvaughan
+1 check your fluid and keep it full. a minor leak won't hurt anything as long as you keep it full.
Old Jun 22, 2009 | 10:23 PM
aim4squirrels's Avatar
aim4squirrels
How does the fluid taste?
