Upper Console Removal
Old Jun 23, 2009 | 06:40 PM
paco1128's Avatar
paco1128
Default Upper Console Removal
Does anyone know how to remove the upper consul on a 2000 Dodge Ram? My map / reading lights don't work and the bulbs are fine. Something seems to wrong with the switch.
I can't pull the plastic cover off. There are push tabs that loosen the front of the consul and the back seems to pull out after sliding it back, but there seems to be something holding it in the middle and I can't find what's holding it.
Any thoughts? I appreciate the help and tahnks again for having me as a member!
Old Jun 23, 2009 | 09:42 PM
Trey318's Avatar
Trey318
Originally Posted by Service Manual
REMOVAL
(1) Disconnect and isolate the battery negative
cable.
(2) Open the garage door opener storage bin door
and locate the two overhead console latch tabs near
the front of the bin (Fig. 4).
(3) While pulling gently downward on the front of
the overhead console, push the latch tabs forward
until each latch is disengaged from its receptacle in
the inner roof panel.
(4) Slide the overhead console rearward far enough
to disengage the two mounting hooks on the rear of
the housing from the mounting holes in the inner
roof panel (Fig. 5).
(5) Lower the overhead console from the headliner
far enough to access the wire harness connector.
(6) Disconnect the roof wire harness connector
from the overhead console wire harness connector.
(7) Remove the overhead console from the vehicle.
Thats directly quoted from the 2001 service manual. The 99-01 is a little different than what I have.
Old Jun 24, 2009 | 09:05 AM
paco1128's Avatar
paco1128
Trey - Thank you SO much!!!
Old Jun 24, 2009 | 10:37 PM
Trey318's Avatar
Trey318
Not a problem
Old Dec 29, 2009 | 02:54 AM
jjtroutbum's Avatar
jjtroutbum
bet this is different than my 96's but I'm bumping it till tomarrow
Old Dec 29, 2009 | 03:05 AM
Laramie1997's Avatar
Laramie1997
lol Yea, it is a little different. It's been forever since I've had mine off, but I think I can get you close.
There is 2 screws up towards the windshield. Remove those, and you should be able to slid back towards the seats. Do it carefully though! Dodge plastic likes to break and you have connected wires up there.
btw, What is a Flowmaster Force II exhaust? Been almost a year since I've bought any of their products, and I don't recall ever hearing about a kit/cat back named that... End question: What series is it?
Old Dec 29, 2009 | 04:07 AM
jjtroutbum's Avatar
jjtroutbum
http://www.autoanything.com/exhausts...A3548A0A0.aspx
I believe its a 70 series. It gets compliments!! Sounds good while the peddle is down and I hardly notice any drone when its at speed.
Thanks for the info provided above need to rewire my radar detector figure ill tap in up by the headliner.
