Driveshaft question?
Old Jun 25, 2009 | 07:03 PM
squirel022003's Avatar
squirel022003
Default Driveshaft question?
I have a 94 Ram 1500 Long Box 5.9L 2WD with only 204,000 miles on it. My question is on the driveshaft. I got under there the other day and noticed a crack in the plastic casing that goes around what seems to be carbon or fiberglass. I am only getting a very slight vibration but do intend to get it replaced. Should I be worried that the shaft will split in two or is this just to protect the shaft from the elements. I dont want to keep driving it until I find a cheap used one if this is a major saftey concern. Please let me know your thoughts.
Thank you,
A proud Dodge owner Lee
Old Jun 25, 2009 | 07:09 PM
dhvaughan's Avatar
dhvaughan
i thought drive shafts were steel or aluminum. i don't get out much but i've never heard of carbon or fiberglass. are you sure ?
Old Jun 25, 2009 | 07:24 PM
Sheriff420's Avatar
Sheriff420
are you talking about the drive shaft or the housing on the back of the transmission that the yoke slips into?
Old Jun 26, 2009 | 07:49 PM
squirel022003
Default Driveshaft Question
No it is definatly the drive shaft. There is a crack in the Black plastic that goes around the shaft. Under the cover there is a chauky while powder on it. Im not sure maybe the drive shaft is aluminum under there but the plastic is still cracked just curious what anyone thinks.
Thank you,
Old Jun 26, 2009 | 09:34 PM
Miami_Son's Avatar
Miami_Son
I think you need to get us a picture because AFAIK all Dodge full-size trucks use steel driveshafts.
Old Jun 26, 2009 | 09:36 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Not his.
