piston rings
Old Jun 27, 2009 | 08:01 PM
engineblock's Avatar
engineblock
Default piston rings
How can i check if i have bad piston rings or pistons without removing anything major?
Old Jun 27, 2009 | 08:28 PM
dhvaughan's Avatar
dhvaughan
check for excessive blue smoke.
run a compression check. look for something like 130-150+ psi, reasonably equal across all cylinders, say with 10-15 pounds.
why do you think you might have bad rings ?
Old Jun 27, 2009 | 08:35 PM
engineblock
cause i have smoke coming out the exhaust, i already did the valve stem seals, the plenum gasket (but i torqued it to much still checking that) and the last thing to check is the piston rings.
Old Jun 27, 2009 | 09:01 PM
Miami_Son's Avatar
Miami_Son
Compression test can't tell you if it's the rings or the valves or the valve seals. Only a cylinder leak down test can pinpoint the real cause. It doesn't require any tear down, but is a little more involved than a compression test.
http://www.aa1car.com/library/leakdown.htm
