Plugged cat Q??
Old Jun 29, 2009 | 08:35 AM
aoneill's Avatar
aoneill
Default Plugged cat Q??
I spoke to the muffler shop today, he said if the cat is plugged, he won't just hollow it out because the stuff will kill you in there.. He will though put on another peice of strait pipe..Will this affect the truck?? 97 Ram 5.2 4x4. O2 sensor needs changin as well (upstream)
thanks
Old Jun 29, 2009 | 08:58 AM
Hammer Down's Avatar
Hammer Down
This should, from what I understand, have no adverse affects on the way that your truck runs. The upstream O2 sensor is the only one that can change your air fuel mixture. The downstream sensor only checks for catalytic converter functionality. If you replace the cat with a straight pipe, your truck will probably run better, but your check engine light may also come on because of that downstream O2 sensor recognizing that your cat (or lack there of) is not working right. Hope this helps.
Old Jun 29, 2009 | 11:01 AM
dodge15004x45.9's Avatar
dodge15004x45.9
To fool the o2 check this out.
http://www.thefastman.com/02Simms.asp
Old Jun 29, 2009 | 11:26 AM
gobbell1's Avatar
gobbell1
I gutted my cat several months ago. Best decision I ever made. No adverse effects what-so-ever.
5.9l 2wd
Old Jun 29, 2009 | 02:03 PM
audiomechanic's Avatar
audiomechanic
I attempted to gut mine a few days ago. It's amazing how hard that crap is in there!!! I spent a good hour with a long metal bar beating and beating a beating a beating until I had blisters on my hands!!!! Finally, I made it through. My reward? A 3/4" hole in the catalyst. That's it. I think a drill with a 1" paddle bit shoved in there ought to grind it up.
I patched the pipe back together with a pipe coupler and a couple of u-clamps so at least I can remove it again to finish the job.
Old Jun 29, 2009 | 03:06 PM
hometheaterman's Avatar
hometheaterman
That's what I run even though I have a cat. I didn't know if the high flow ones would throw a code or not and since I needed a 02 sensor at the same time I just bought one of those. Turns out it doesn't throw a code with a high flow cat but I still put that one anyway.
Old Jun 29, 2009 | 04:02 PM
dodge15004x45.9
Yea I was just throwing it out there in case his did throw codes there is a fix.
Old Jun 29, 2009 | 04:11 PM
lastrights's Avatar
lastrights
yeah our 2nd gens , are prone to having clogged cats , you can either gut it , or go a safer route and get a magnaflow highflow cat for replaceing the stock one .
Old Jun 29, 2009 | 04:14 PM
dodge15004x45.9
It depends what state his is in? Which one are you in???
Old Jun 29, 2009 | 04:48 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Rather than spending the money on a sim , if it does throw a code you can first try the spark plug non- fouler trick.
