Plenum fix kit... same problem
Old Jun 30, 2009 | 10:35 PM
wkdaywarrior's Avatar
wkdaywarrior
Default Plenum fix kit... same problem
So I just recently installed the new Hughes plenum fix kit that I purchased. Along with some other bolt on goods while i was in there and theres one small problem. When I really get on it, and it hangs around 28-3 grand, i get my pinging back, the same pinging i had before i put the kit on. Now granted its not nearly as bad as before but i thought this was supposed to fix it completely? Is there any other suggestions? Plugs? Fuel additives? could it just be a coincidence and maybe have some bad gas? Thoughts appreciated, Thanks.
Old Jun 30, 2009 | 10:45 PM
dodge15004x45.9's Avatar
dodge15004x45.9
The Hughes kit dose not fix the ping. Just the plenum plate. You can try runing a higher grader of gas.
Old Jul 1, 2009 | 01:26 AM
jasonw's Avatar
jasonw
Site Moderator
The Hughes kit should help with the original problem causing the pinging. However...
The damage possibly done by the leaking plenum gasket, that you fixed, might still need to be addressed.
Clean the throttle body, being careful with the sensors as you remove them. Also, you may want to replace the pre-cat oxygen sensor, as it is more than likely fouled a bit as well. After that, disconnect the negative battery terminal. Turn on the headlamps for several seconds, then turn them off. Reconnect the negative battery terminal. That should reset the PCM, clearing its memory and forcing it to "relearn" from the sensors.
Old Jul 1, 2009 | 01:40 AM
dodge15004x45.9
The headlamps?
Old Jul 1, 2009 | 01:56 AM
dakotas ram's Avatar
dakotas ram
or try to start it....youre just draining the juice out of the system
what other bolt on goods did you put on? ....also run some seafoam or equivalent thru it to clean the valves and chambers
Old Jul 1, 2009 | 02:39 AM
jasonw's Avatar
jasonw
Site Moderator
Or you can wait for several minutes. The headlamps drain any residual power left in the system, faster than waiting.
Old Jul 1, 2009 | 02:49 AM
dodge15004x45.9
I though you had to like push they trip thing on the dash. I got yelled at by sliver about it.
Old Jul 1, 2009 | 02:52 AM
jasonw's Avatar
jasonw
Site Moderator
You get yelled at a lot.
Old Jul 1, 2009 | 03:02 AM
dodge15004x45.9
Yea oh well comes with being new. It was not to check to see if there was any codes.
Old Jul 1, 2009 | 03:42 AM
dhvaughan's Avatar
dhvaughan
one more time.... pay attention, learn it, repeat it correctly, and you won't get yelled at.
to run the gauge test on later models - turn ignition key on while holding in trip meter.
to show codes - turn ignition key on, off, on, off, on.
to reset pcm - remove neg battery cable, then either turn on headlights for 30 sec, or, turn ignition to start for 30 sec. the open circuit drains the power that holds pcm memory values.
wkday - you still have something wrong. either another vac leak, carbon buildup in cyl, or something too hot or too lean. as said by dodge above, try some 89 octane to see how much it takes to eliminate your ping. it should not take any, but since there's still a problem, find out how much it takes. 1/4 tank, or 1/2, or what. check vac lines, incl 4wd cad lines.
