Window won't go up on passengers side
Old Jul 15, 2009 | 11:22 AM
tresvatos's Avatar
tresvatos
Default Window won't go up on passengers side
My window won't go up on the passengers side of my 96 Ram. it will however go up from the drivers side switch..Is this a bad passengers switch , or what? Thanks
Old Jul 15, 2009 | 12:02 PM
2001Ram's Avatar
2001Ram
Sounds like it, take the passenger side switch out, and there should be copper little contacts that the switch touches. you can bend them back into place and test it. If it works, there is your problem.
Old Jul 15, 2009 | 02:32 PM
Laramie1997's Avatar
Laramie1997
So, you can roll the window up on the driver's side, but not the passenger? If that's the case then yea, you need to check that switch.
