downshifting to much
Old Jul 18, 2009 | 07:12 PM
neadspeed's Avatar
neadspeed
Default downshifting to much
I have a 1998 dodge 4x4 with 285/75/16. When i am driving on the highway a 70 to 80 mph the truck is shifting into 3rd gear. on my trip from las vegas to sioux falls sd i spent at least half the miles in 3rd gear. Is this normal with over sized tires or is there anything that i may need to look at? any suggestions would be great
Old Jul 18, 2009 | 07:41 PM
dodgeram2001's Avatar
dodgeram2001
dang im not sure but , sounds like u need to check ur fluids an if thats not the problem check ur brakes make sure nothings holding out like if one is clamped down like stuck or the emergancy brake cable check that , an if u do im not sure but i know on my big truck i had it was doing the same thing wich was the dam carryer bearing went out so check thoes an if nothing go to a tranny shop an see what they say ? let US know ?
Old Jul 19, 2009 | 10:42 AM
neadspeed's Avatar
neadspeed
i will check all those things tomorrow
Old Jul 21, 2009 | 08:51 PM
MonteC's Avatar
MonteC
You should be in 4th gear and lock up by 70 or 80.
Old Jul 21, 2009 | 10:28 PM
dhvaughan's Avatar
dhvaughan
a faulty throttle position sensor (tps) or brake light switch will cause it to excessively downshift. also a leaking plenum saps the power. a new tps ($45) helped mine tremendously.
