Need help quick!
Old Jul 23, 2009 | 10:14 PM
  #21
hammer_down's Avatar
hammer_down
so no luck here on advice other than what was already said? thanks guys
Old Jul 23, 2009 | 11:08 PM
  #22
xray99's Avatar
xray99
What steps exactly have you taken so far ?
Spark sounds good, so most likely fuel/sensor related, could even be a clogged filter.
Old Jul 25, 2009 | 03:43 PM
  #23
hammer_down
well i got a fuel presure gauge and my chiltons and am gonna test pressure but it wont run, and i am pretty sure you have to test it at idle? also arent the filters like, inline with the pump on these trucks?
Old Jul 25, 2009 | 06:09 PM
  #24
Miami_Son's Avatar
Miami_Son
Filter is inside the pressure regulator housing and is not serviceable. You don't need the engine running to check fuel pressure. It is an electric pump and does not run off the engine.
Old Jul 25, 2009 | 06:57 PM
  #25
hammer_down
well, when my truck quit running i bought plugs and a new air filter and some odds and ends...well after i changed out the plugs, and put some gas in a new spray bottle and fired some in the intake and cranked it, it fired up and ran, but popped or misfired about every 5 seconds an ran in a generally nasty fashion... so i i thought, oh, i crossed a plug wire, right? so i started checking everything again and found plug that will neither tighten or loosen, doesn't seem to be broken off and it is still in there firmly but wont all the way tighten OR back out, so im sure i did something f@#%in horrible and stupid, and will probably take it some where to get unstuck before i get it any more fu&!ed up any worse than stupid self did. if it the fuel pump or somethin IS bad than i will tackle that myself... oh well live and learn right? thanks guys....if anyone might an an idea before too long and posts it ill try... if no thanks alot for your time!
Old Jul 26, 2009 | 01:25 PM
  #26
PurplDodge's Avatar
PurplDodge
Originally Posted by 97black_ram
No prob. I'm in Ohio and I don't plan on ever making a trip to TX.
Well, then Stay away from my truck!
Old Jul 26, 2009 | 02:56 PM
  #27
Ram15002ndGen's Avatar
Ram15002ndGen
Shouldn't that be Trucks?
