keyless entry
Old Dec 31, 2009 | 02:51 PM
koaea's Avatar
koaea
Default Programming process
Looks like we are 'remote ready' if the automatic door locks lock when the truck gets to 15mph.
Also, here's the programming process:
Programming Additional Transmitters
Up to four transmitters can be programmed. When programming a new transmitter, all transmitters intended for use with this vehicle, except the transmitter used to start the programming mode, must be programmed within the 30-second programming mode. To program a transmitter, turn the ignition switch to the ON position with the vehicle stopped. Press and hold the unlock button on a currentlt programmed transmitter for a minimum of four seconds and a maximum of ten seconds. While pressing the unlock buttor, press and release the panic button. Release the unlock button and a single chime will sound. This indicates that the module is in programming mode. Within thirty seconds, press and release the lock or unlock button on all transmitters intended for use with this vehicle except the transmitter used to start the programming mode. Successful programming will be indicated by a single chime.
NOTE: When programming mode is entered, programming is cleared from programmed transmitters and the transmitters will need to be reprogrammed.
http://dodgeram.info/tech/operation/RKE/index.html
Hope this helps!
Old Jan 2, 2010 | 11:22 AM
bigtman07's Avatar
bigtman07
That's very helpful info. But do the door locks have to lock while going down the road to have an alarm? Mine don't do that but the keyless works fine. Any clue about the auto lock or is my 98 too old?
Old Jan 3, 2010 | 10:19 AM
Sheriff420's Avatar
Sheriff420
you can activate/deactivate the auto lock at 15mph with a few key turns and hitting the lock button.
when i got my truck i was reading the user manual and saw that and it wasn't enabled, so i turned that feature on. that was before i got a key fob also.
Old Mar 23, 2010 | 09:05 AM
rick.svelnys's Avatar
rick.svelnys
Hi I am rick. This is a great forum to have registered with,I just purchased a 2000 Durango R/T on ebay.I am very lucky, it is so nice! I need to find a place near CT. to get a second remote for the keless entry for my wife.I did copy the ignition key at the hardware store,but I need the procedure to program the remote when I find one.
Thanks, rick.
Old Mar 23, 2010 | 09:59 AM
Sheriff420's Avatar
Sheriff420
You can get one on ebay for 20-30$
Do a search. I did a quick search and this is one of many that I saw.
http://cgi.ebay.com/ebaymotors/2000-...Q5fAccessories
Old Mar 23, 2010 | 11:28 AM
MrRuckuss's Avatar
MrRuckuss
read your owners manual in there it has instructions on how to do that, i didn't have to pay the dealer but he told me that it would cost $70 to program it. afterwards he told me to look in the owners manual and sure enough there they were...the instructions
Old Mar 23, 2010 | 12:20 PM
Sport1500's Avatar
Sport1500
I bought a used oem remote on eBay and am going to have it programmed at the dealer since my truck didn't come with any remotes . Not sure what the previous owner did with them since I bought it at a used car dealer.
Rob
Old Mar 23, 2010 | 01:50 PM
bigtman07's Avatar
bigtman07
Well let us know how that goes. Aparently the auto lock feature is on 99 and newer rams. So I dunno how many remotes I can have. I know I have 2 now. Would like to have a spare. but who knows.
