Leaking Coolant
Old Jul 25, 2009 | 01:23 PM
driversound's Avatar
driversound
Default Leaking Coolant
Hey guys, I have a 2001 5.9 and it seems to be leaking coolant from somewhere and I haven't tracked it down. Anybody know where the weep hole is on the water pump? It seems to be wet around the water pump but the pump itself is dry. Any help is appreciated. Thanks.
Old Jul 25, 2009 | 01:28 PM
Sheriff420's Avatar
Sheriff420
its hidden above the balancer
Old Jul 25, 2009 | 01:40 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Upper rad hose, thermostat housing, by pass hose, engine coolant temp sensor, timing chain cover. Check them all. And the hole is behind the WP pulley on the bottom of the WP.
Old Jul 25, 2009 | 02:30 PM
dhvaughan's Avatar
dhvaughan
the weep hole is directly above the big green drip on the bottom.
Old Jul 25, 2009 | 02:38 PM
zman17's Avatar
zman17
That's another good place to look. DV has it right again.
Old Jul 25, 2009 | 03:12 PM
driversound
Thanks for your help guys, I'm just gonna have to take it apart. It looks like it's coming from the wp gasket though.
Old Jul 25, 2009 | 03:35 PM
zman17's Avatar
zman17
It's rare that it would leak from there, and more common for it to leak at the timing cover to block. Clean everything off and check it out real good. Try tightening all the bolts on the front of the motor first also.
