fixing the rear main
Old Aug 1, 2009 | 04:18 PM
360mag45's Avatar
360mag45
Default fixing the rear main
ok im fixing the rear main and front main on my truck. and im gonna take the hole weekend and just replace all the fuilds in the truck (expet brake and steetering).
But the trucks maual is not to clear on which fuilds to use on the front and rear dif. and the automatic transmission fluid. also with replacing the tranny fuild is there a filter that should be replaced to.
tranny is an automatic 46re
Old Aug 1, 2009 | 04:25 PM
Miami_Son's Avatar
Miami_Son
http://dodgeram.info/tech/BRSpecs/fluids/specs.html
Use ATF4+ in the tranny. And yes, there is a tranny filter.
Old Aug 1, 2009 | 04:33 PM
360mag45's Avatar
360mag45
thank you
Old Aug 2, 2009 | 10:43 AM
Sheriff420's Avatar
Sheriff420
80w90 front and rear. if you tow a lot get 75w140 for the rear.
Old Aug 2, 2009 | 12:05 PM
360mag45's Avatar
360mag45
other than the oil pump is there anything else that would be a good idea on replace while i have it all torn apart
Old Aug 2, 2009 | 12:19 PM
dodgeram07's Avatar
dodgeram07
http://www.pavementsucks.com/tech/rearmain.php
