Stock Intake Gaskets and Seals
Old Aug 2, 2009 | 12:45 PM
terranova's Avatar
terranova
Default Stock Intake Gaskets and Seals
Just need a run down on what gaskets and seals I will need to replace everything since I'm doing my plenum, water pump, and timing chain.
Old Aug 2, 2009 | 12:53 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Thermostat gasket. And since you'll have the intake off, it's a good time to do cap,rotor and wires. I'm assuming you already know you need the others you mentioned. The timing chain gasket set will have the WP gasket also. A new by-pass hose also.
And get FelPro gaskets, if you plan on using the stock plate, make sure the bolts are not too long. Grind off the the end of them that have no threads.And use blue Loctite.
Old Aug 2, 2009 | 03:37 PM
BlueBeast2's Avatar
BlueBeast2
I have a Hughes pan and the gaskets and bolts. All brand new never installed. I was gonna keep the stock intake but then the new hughes one came out so I got it. I'd like to get as close to what I paid for it back. If you want make me an offer.
