huh!!! now im pissed
Old Aug 5, 2009 | 11:35 PM
  #21
dhvaughan's Avatar
dhvaughan
i had to look that up...
Narcolepsy is chronic sleep disorder, or dyssomnia. The condition is characterized by excessive daytime sleepiness (EDS) in which a person experiences extreme fatigue and possibly falls asleep at inappropriate times, such as whilst at work or at school.
Old Aug 5, 2009 | 11:57 PM
  #22
Trey318's Avatar
Trey318
Did the particle accelerator crap out on ya? I hate when that happens..
Old Aug 6, 2009 | 01:26 AM
  #23
95MaroonMonster's Avatar
95MaroonMonster
flux capcitor?
Old Aug 6, 2009 | 02:13 AM
  #24
jasonw's Avatar
jasonw
Site Moderator
Originally Posted by mr freeze
Your truck is narcoleptic????
I know I originally said battery or ignition coil, but I like Mr. Freeze's explanation better.
Old Aug 6, 2009 | 02:23 AM
  #25
dakotas ram's Avatar
dakotas ram
maybe it just got some ford motivation
Old Aug 6, 2009 | 08:02 AM
  #26
olyelr's Avatar
olyelr
Originally Posted by 95MaroonMonster
flux capcitor?
Old Aug 6, 2009 | 10:47 AM
  #27
Sheriff420's Avatar
Sheriff420
check the battery connections. if one is loose then it might do that. my negative cable was loose one time and it made my volts max out on the gauge, it might also kill it if yours is loose.
Old Aug 6, 2009 | 08:39 PM
  #28
2damnyankee's Avatar
2damnyankee
Ok you guys had some good ones
a narcoleptic i had to look it up also then i seen the definition on the next page.
flux capacitor pretty good
Ok the answer the the strange shut down.
is the stock coil had gotten a crack it and it was hot as h3ll to.
so thats when i figured not to run it even if it did start and call my buddy.
Once it cooled down it would start. so now i have a MSD coil and going to get the MSD 6AL box later this month. (as long as the wife dont find out)
Also as for my buddy next time his JUNK breaks down and he calls me I'm going to show up with a scooter pulling my small garden trailer. That will teach him to show up with a ford.
Old Aug 6, 2009 | 08:49 PM
  #29
Crazyredneck21's Avatar
Crazyredneck21
Fuel pump was going to be my guess. Mine went out in my 94 Ram that I had. Three of the four legs from the top of the tank to the pump broke, leaving the fourth to support the pump. As the pump moved back and forth, riding the wave of gas in that huge tank, the pump would loose ground and stop running. Had mine towed twice before I figured out the problem.
Old Aug 7, 2009 | 01:13 AM
  #30
dakotas ram
what do you have so bad against fords? at least you got a pull.............
