PCM fault codes
Old Mar 25, 2005 | 04:28 PM
raygauthier245's Avatar
raygauthier245
Default PCM fault codes
hi there !!
this is my problem is a fault code .
I have a 97 Dodge Ram laramie 5.9L 360 with a code that reads
Code 43 Ignition coil circuit #
Open or short in number # coil circuit. Indicates that the ignition coil's peak primary circuit current is not achieved with the maximum dwell time.
but if you go under the truck it makes a noise like a rattle like small rocks in a coffee can coming from the catalytic converter and it is just beside the transmion hard to tell if it from the transmion or catalytic converter.
When i am driving a have a lack of power and you can here the rattle.
So my Question is can a catalytic converter bring up this codes or is my truck in bad need of help
Did this happen to anyone
[sm=partyparty.gif]
Old Mar 28, 2005 | 02:13 PM
steve05ram360's Avatar
steve05ram360
Default RE: PCM fault codes
sounds like 2 problems to me... 1) your cat is bad because of the rattle, the brick in there is split and the rattle you hear is the brick banging around in there. 2) your coil code sounds like the one you get when you install an aftermarket ignition like an MSD, I have the same problem right now and it's because it needs an MSD 8910 tach adapter installed. if you have the stock igntion setup, then your coil is probably going bad. swap in a 8228 MSD coil, (you might need the accell adapter for the wiring)
start with your cat...
