Anyone swap in a FF14 in the rear os a second gen?
Old Aug 8, 2009 | 11:01 AM
chris101's Avatar
chris101
Originally Posted by Jr. Mechanic
The hole in my D35 case from an exploded pinion bearing will tell you that
Wow JR, I used to have a car almost identical to that, It was black on black with t tops, 1983 Z28, Had a 305 adn a 5 speed. I put a 350 roller motor in it. Had posi rear end with disk brakes. Man i miss that car.
Old Aug 8, 2009 | 11:04 AM
95MaroonMonster's Avatar
95MaroonMonster
ive seen a guy put the pinion through the cover, going up a hill in low range, he nailed the skinny petal, and pulled the front end up off the ground
Old Aug 8, 2009 | 11:07 AM
chris101's Avatar
chris101
How'd he get the pinion thru the ring gear to get to the cover? I think you meant ring gear?
Old Aug 8, 2009 | 11:14 AM
95MaroonMonster
i remember reading it in a magazine, the rearend grenaded, and a chunk of the pinion came haulin *** out of the diff cover
