Fresh Rebuild and lifters are clattering
Old Aug 18, 2009 | 08:27 AM
palerider9999's Avatar
palerider9999
Default Fresh Rebuild and lifters are clattering
I just did a complete stock overhaul of my 1998-360 and not real happy with the results. I replaced the lifters during the build and they sound completly dry during initial daily start up. They bleed down after 6+ hours and I am getting very disgusted. The lifters were a direct factory replacement purchased from Napa. (Part #HT-2269 Fed Mogul) I just switched to a 20-50 oil and that seemed to quiet a most of them but I'm guessing 3-4 are being very stubborn. I have great oil pressure at start up usually close to 60 lbs then running psi is a steady 40. I also switched oil filters to the larger Napa Gold unit. Once pumped up, they are quiet and the motor purrs like a kitten. During the rebuild, I positioned the lifters so the small oiling hole was facing the center of the motor. I did check a junk yard motor to verify I was placing them into the bores correctly. The motor has about 1000 miles on the rebuild.
Also not happy with the stock cam. I wasn't able to get a good feel for one that would not cause computer issues but give me what I need for the occasional towing but that's another issue.
Any suggestions?
Old Aug 19, 2009 | 03:07 PM
palerider9999
Bump..
Old Aug 19, 2009 | 05:01 PM
Dodgeman000's Avatar
Dodgeman000
are they adjusted properly. i know they are hydrualic but the botls could of backed off oh and check your pushrods
Old Aug 19, 2009 | 08:45 PM
palerider9999
Default Noisy Lifters
We used locktite and they are only noisy at start up. I did check the pushrods during rebuild but maybe I should pull the valve covers just to double check...
Old Aug 19, 2009 | 08:50 PM
2damnyankee's Avatar
2damnyankee
by any chance did you let them soak in oil before you installed? they may have a air pocket in them that needs to bled out now by the motor, Oh and plus 1 on checking the rockers and see if they backed off and since you will have off the covers pull the push rods and see if you got some clogged ones. also marvel mystery oil will help with the lifter tap
Old Aug 19, 2009 | 10:51 PM
Ram15002ndGen's Avatar
Ram15002ndGen
Try going straight 30 weight for a few miles and see if that helps having consistent oil thickness to lube everything in properly.
Old Aug 20, 2009 | 02:22 PM
palerider9999
Ok on both and I will try those suggestions after coming back from over a 2 hour trip pulling a heavy camper... Hope she stays together and I'll give an update later.
Old Sep 2, 2009 | 06:17 PM
palerider9999
Here's the update since that is one of my pet peeves about forums. I tried the Marvel Mystery oil and made 4-2 hour trips pulling my heavy camper. The lifters are not clattering at start up now! They seem to be holding prime and the truck is actually very quiet now. I parked it when I got home and let it set for 3 days and they were fine when I started it today. I'm not sure if it was the oil, the long trips or a combination of both but it did cure the problem. Next is the rear end rebuild.
