Vibration damper to crankshaft bolt, what size?
Does anyone know the bolt size for the vibration damper to crankshaft on a '99 dodgeram 1500 5.9L? thanks!
nm, i found it. thanks.
EDIT: 32mm was just perfect... wasn't loose at all hehehehehe. |
dammit. here's how this works....
you ask a question. somebody answers it (even if its you). then 100 more people come along and benefit by doing a search and reading the question and the ANSWER. like this: Q. what is the size of the crank bolt on the harmonic balancer ? A. 1-1/4 in. socket is $6 at autozone. that's 31.75mm so 32mm might work, but would be a tad loose. |
