brake caliper paint??
Old Aug 20, 2009 | 11:54 PM
96rumbledodge's Avatar
96rumbledodge
Default brake caliper paint??
cant seem to find it where can i get it how much and how difficult is this
Old Aug 20, 2009 | 11:59 PM
JackTheStripper5.9's Avatar
JackTheStripper5.9
I don't know if it's called caliper paint but you can use high temp engine paint too. It'll work the same as long as it's high temp. Make sure you clean them real good before painting. Maybe give them some media blasting if they're bad.
Old Aug 21, 2009 | 12:39 AM
Ram15002ndGen's Avatar
Ram15002ndGen
I used Rustoleum on my Mustang calipers and it has held up nicely.
Old Aug 21, 2009 | 01:06 AM
RM_Indy's Avatar
RM_Indy
Duplicolor has kits specifically for brake caliper. Available in blue, red, black, yellow and silver.
Used their silver on my alt/ac bracket and pwr steering bracket. My old M1/2BBL was silver with black detail, calipers in red, spindles I used the blue. My new M1/4BBL is coated with specialty heat releasing coating but detailed with silver/blue. Water pump used silver. Timing cover used their black and detailed with silver.
Not that difficult to do. Must get it spotless though for the paint to stick well. More coats you give it, the smoother the surface will be.
Old Aug 21, 2009 | 01:33 AM
dakotas ram's Avatar
dakotas ram
you can get it from parts stores and even some walmarts
Old Aug 21, 2009 | 09:53 AM
dsertdog56's Avatar
dsertdog56
I know O'riellys have it. I'd think Autozone would too.
