U joint....input needed please
Old Aug 21, 2009 | 02:26 AM
Bamadodge13's Avatar
Bamadodge13
Default U joint....input needed please
My driverside u-joint on the axle shaft is bad and i am goin to replace it but i was wondering if the axle shaft has a c-clip in the axle housing like most...if not i could just pull the axle out. But if not i have to take the diff cover off and pull the whole front end apart...so i was wonderin if anybody knew...its a 01 1500 with dana 44's i think....thankyou
Old Aug 21, 2009 | 03:16 AM
xxxtina63's Avatar
xxxtina63
The axle just pulls out, at least on my 96, which I assume is the same set up w/D44.
Old Aug 21, 2009 | 10:07 AM
97black_ram's Avatar
97black_ram
There's no c-clips in the axle housing. Remove the tire, the rotor, the hub nut, three bolts on the back of the hub and off comes the hub and out comes the axle.
Old Aug 21, 2009 | 10:29 PM
dhvaughan's Avatar
dhvaughan
when you reinstall the axle, cover the end with a lot grease and slide it in very very gently and use all the care you can to avoid tearing up the oil seals that sit at the differential end of the axle tube. or else you'll be taking taking it all apart again and pulling out the damn differential.
Old Aug 21, 2009 | 11:40 PM
Sheriff420's Avatar
Sheriff420
pulling the carrier and both axles out just to get to a little 13$ seal sucks so be careful reinstalling the axle.
Old Aug 22, 2009 | 02:56 AM
Bamadodge13
appreciate the imput thanks yall
Old Aug 23, 2009 | 12:56 AM
dodgeram2001's Avatar
dodgeram2001
slide her right out i did today it was nice .
