A/C vacuum leak
Old Aug 29, 2009 | 06:16 PM
Pyromanaron's Avatar
Pyromanaron
Default A/C vacuum leak
There is a vacuum leak somewhere in my A/C system. I think its the soft plastic connector on the back of the switch, in the dash. Is this part known for leaking?
Attached Thumbnails A/C vacuum leak-dscf0017.jpg
Old Aug 30, 2009 | 11:05 AM
Sheriff420's Avatar
Sheriff420
i have a leak too but i haven't thought to check out that connection. blow some smoke at it with the ac on to see if it gets sucked in. if you don't smoke then light some incense or a piece of cardboard and blow out the flame so its smoldering.
Old Aug 30, 2009 | 03:33 PM
Steel Horse's Avatar
Steel Horse
i belive i have a ac vacuum leak to cause when i give it gas the blower stops blowing and when i let of the gas it starts blowing again
Old Aug 30, 2009 | 03:35 PM
speeddemon31176's Avatar
speeddemon31176
Check out a post called wild vents. It will show you where to check for the common vacuum leaks to fix that problem.
Old Aug 30, 2009 | 05:06 PM
eaglestorm's Avatar
eaglestorm
A vac leak wont cause the blower to stop working it's elec but it will cause the mode doors to shift to default post (defrost) ck all your lines outside and under the battery where the cruise controll servo is thats where most leaks are
Old Aug 30, 2009 | 08:32 PM
speeddemon31176
It sounds like it has stopped working because it shifts to the defrost mode. I think most of the guys on here have experienced it and we all know the remedy to this, so while I did not directly address his claim of the blower motor stopping we all know what the fix is.
