Idle issue
Old Sep 4, 2009 | 05:56 PM
mr_blove's Avatar
mr_blove
Default Idle issue
I am trying to help my buddy fix his '96 ram 2500 with the 5.9L gas engine and we are having no luck. You can start it and as long as you keep your foot in the accelerator reving it, it will stay runnning, when you take your foot off to let it idle it dies. So far we have replaced the IAC sensor and the TPS sensor. It appears there is slack in the throttle cable, is that normal? All help would be appreciated.
Old Sep 4, 2009 | 06:55 PM
Ram15002ndGen's Avatar
Ram15002ndGen
No, there should be no slack in the cable. I think the Haynes manual shows how to adjust it.
Old Sep 5, 2009 | 03:59 PM
dungholio's Avatar
dungholio
this may sound a little strange but, have the battery tested. with these dodges, if the battery has even a dead cell, but still has 12 volts and cranks over just fine. well it screwes with the computer and will not run well. if thats ok then you can adjust the idle. could be set to low. also when you adjust the throttle cable, be carefull because you can actually mess with the tranny kick down cable which will change you shift points. arent dodges great haha!!
Old Sep 5, 2009 | 05:25 PM
speeddemon31176's Avatar
speeddemon31176
You state that you replaced the IAC and TPS but did you thoroughly clean the throttle body especially where the IAC mounts? If not then that could be your problem.
Old Sep 5, 2009 | 05:26 PM
frankie27's Avatar
frankie27
does it run fine when driving?
