ABS and Brake Lights On, Pulsing in Pedal
Old Sep 7, 2009 | 04:30 AM
tj1320's Avatar
tj1320
Default ABS and Brake Lights On, Pulsing in Pedal
What the title says is pretty much what the problem is. The lights come on and go off every now and then, however more and more frequently as I drive it, and the brake pedal "pulses" like the ABS is engaging. It usually does this when I am slowing down and hitting bumps in the road. I've heard that it could be a sensor but none of those threads seemed to mention the pulsing. Please advise.
Old Sep 7, 2009 | 02:08 PM
95RAM360's Avatar
95RAM360
could be a number of things that could cause this
-frozen caliper slides
-fluid is boiling
-air pockets in lines,
-master cylinder
-frozen calipers
Old Sep 7, 2009 | 03:38 PM
J415's Avatar
J415
Just to be clear, do you have front wheel ABS?
Old Sep 7, 2009 | 03:48 PM
charlie1935's Avatar
charlie1935
Could be a bad ABS sensor tricking the ABS control into thinking a wheel is locking up.
May need to have the brake system scanned.
Old Sep 7, 2009 | 06:13 PM
tj1320's Avatar
tj1320
Damn, that sounds all bad. It has rear wheel ABS and I went to Autozone today and purchased an ABS sensor that I will be installing in a few minutes. God I hope that fixes it but your responses are not encouraging. Thanks for the advice though.
Old Sep 8, 2009 | 12:48 PM
J415's Avatar
J415
If you don't have front wheel ABS, then you don't need an ABS sensor. If I understand you correctly, you only have REAR WHEEL ABS?
Old Sep 8, 2009 | 03:29 PM
charlie1935
May be more than one problem.
Pulsating may be warped rotor and the light the sensor on the rear end.
Old Sep 8, 2009 | 06:30 PM
tj1320's Avatar
tj1320
That is what the window sticker says, rear wheel anti lock. I replaced that sensor on the rear end and the problem seems to have gone away. No more lights and no more pulse in the pedal so hopefully that did the trick. Thanks guys.
