memory check sum error??
Old Sep 8, 2009 | 08:20 PM
andy42s's Avatar
andy42s
Default memory check sum error??
I have an '01 ram 1500 with a 360. My check engine light has been on and off for about a month or 2 now. Some days it's on, some days it's not. I got it checked, and the code reads:
PO601-Internal Control Module Memory Check Sum Error
What does this mean? How can I fix this? Does the whole control module need to be replaced? I don't notice anything unusual. There is no power loss, no misfiring, no wierd sounds. Just the light is on sometimes. Could it be a faulty sensor of some sort? I appreciate any thoughts, ideas or advice!
Old Sep 8, 2009 | 08:26 PM
Oren09's Avatar
Oren09
That means that serial communication within the PCM keeps failing.
The PCM is going bad and has internal shorts.
Old Sep 8, 2009 | 08:54 PM
pcfixerpro's Avatar
pcfixerpro
Im in the same boat as another guy on the forum. Mine pop'd up a month ago. Seems wierd a bunch are failing around the same time. Anyway whatever you do, do not order a rebuilt computer from Auto Computer Exchange!!!! I am currently going through a big ordeal with them right now over a rebuilt computer that was DOA.
Old Sep 8, 2009 | 08:57 PM
Ram15002ndGen's Avatar
Ram15002ndGen
So PCFIXERPRO has the new PCM come in yet or not?
Old Sep 8, 2009 | 09:26 PM
jasonw's Avatar
jasonw
Site Moderator
It means either you have a bad stick of RAM memory or your hard drive is failing...
Oh, this is about the computer in your truck?
Seriously though, I agree with the others, your PCM is failing.
Here is a different eBay seller:
http://cgi.ebay.com/ebaymotors/2001-...Q5fAccessories
