Old Aug 10, 2015, 05:13 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Cooling System Guides
Print Wikipost
Odd coolant leak
Old Sep 10, 2009 | 10:24 PM
sarmikgar's Avatar
sarmikgar
Pressure tested system and during the test it started to leak again.
System seemed to hold pressure pretty well which is why I guess it doesnt overheat during driving.
I think it does leak while running Ive just never seen it because it gets "slinged" off the crank pulley and doesnt get to drip to the ground. With the engine running I can feel droplets on my hand if I put it sorta down near the crank pulley.
Going to throw on new pump and pray that fixes it.
Old Sep 11, 2009 | 08:15 AM
charlie1935's Avatar
charlie1935
Try sticking a finger around and behind the water pump pully, you should be able to feel the weep hole and tell if it is wet or not.
Old Sep 11, 2009 | 11:11 AM
sarmikgar's Avatar
sarmikgar
Its much too tight, I can get about a 1/2" of a finger into the upper pass. side of the pump, but on the bottom of the unit where the weep hole is there is very little clearance.
I am almost positive it is the weep hole though or the shaft seal, because from the bottom of water pump pulley to the crank pulley is where the wetness is. If I stick my finger up into the area where the backside of the belt is riding on the water pump pulley I can get drips on my finger that would normally be running straight down the backside of the belt and around the crank pulley. I think if it were the gasket it would run down behind the crank pulley/damper and off the bottom of the engine.
I may try pulling off the belt and see if I can tell better where its coming from, I should have the new pump in by the end of this weekend and hopefully thatll fix it.
Old Sep 11, 2009 | 01:15 PM
speeddemon31176's Avatar
speeddemon31176
Use an inspection mirror and a flashlight to see if it is the weep hole leaking. I am willing to bet that it is. Put the mirror in where it is angled toward the weep hole and pointthe flashlight at the mirror on an angle to light up the weep hole area. Then go ahead and change the pump since it is leaking.
