2WD RAM gets really bad mileage
Old Sep 15, 2009 | 11:26 AM
Shayna1516's Avatar
Shayna1516
Default 2WD RAM gets really bad mileage
Hey my name is Shayna
Ive got a 1998 ram 2 W.D.,
ive replaced all spark plugs, oil, new oil filter, new air filter had the fuel injectors cleaned and im still only getting 9 miles to the gallon, what else could i do to get better gas mileage?
Thanks
Old Sep 15, 2009 | 01:08 PM
dodgeram07's Avatar
dodgeram07
check these
Plenum gasket- refers to the lower intake manifold plate, where the gasket between it and the intake manifold itself often fails allowing oil and engine vacuum to leak past. Common problem on Chrysler Magnum V8 engines.
the cat,, because they can plug up when the plenum is leaking
o2 senor most likely the on atfer the cat to contor the gas/air mix
Old Sep 15, 2009 | 01:11 PM
95MaroonMonster's Avatar
95MaroonMonster
your driving a dodge, our fuel mileage sucks anyway
Old Sep 15, 2009 | 02:48 PM
dakotas ram's Avatar
dakotas ram
should be better than 9...what engine? tire size?
Old Sep 15, 2009 | 05:59 PM
Twisted Metal's Avatar
Twisted Metal
Welcome to the Fourms. Are you familiar with our Search feature? Honestly there are a multitude of fixes,tweaks,and techniques to improve the fuel mileage. And yes we own Dodge's, the words Magnum and Fuel Mileage don't really go together.
Old Sep 15, 2009 | 06:12 PM
crazzywolfie's Avatar
crazzywolfie
take it to a shop and have the injectors cleaned
Old Sep 15, 2009 | 06:27 PM
Augiedoggy's Avatar
Augiedoggy
you said you replaced the plugs but didnt say anything about the cap, rotor and wires??....these are all things you would replace on a real thorough tuneup. also you never gave us an idea of your mileage on the engine.....oviously a motor with say 250k is likely to be worn and have worse gas mileage than one with 50k on the odometer....mileage has a lot to do with driving habits too...if you like to go from a stop to the speed limit as fast as possible that burns more gas than driving like an old man ...(no offense to any old guys on here)
oh yeah also make sure your tranny is shifting ok....when I bought mine a sensor was bad and it would delay in shifting and wind out to 3500 rpms or so burning a lot more gas...then it quit upshifting completly till i changed it....but a employee with a code reader at the local auto store should tell you if theres anthing wrong with the tranny.
Old Nov 2, 2009 | 04:26 PM
Shayna1516's Avatar
Shayna1516
I've Replaced the wires, New plugs, New rotor, new cap, new air filter, fuel injectors cleaned, new oil & new oil filter. and the truck has 188k miles on it. Shifter tansmission and everything else works good, jus tha damn thing is getting horrible gas milage. I dont know what else to do to it, it's not a 4x4 so im not going to put alot of money into it. Is there anything else that i can do? or should i just go for getting a new truck?
Old Nov 2, 2009 | 04:31 PM
95RAM360's Avatar
95RAM360
is it a 5.2 or 5.9?
my 5.9 4x4 gets about 14-16 city, 19 hywy (just replaced plenum, was 10-12 city before)
my dads 5.2 2wd gets bout 17 city, 21 hywy
Old Nov 2, 2009 | 05:04 PM
lastrights's Avatar
lastrights
look down throttle body for oil
