Led dome light
Old Sep 15, 2009 | 10:27 PM
pcfixerpro's Avatar
pcfixerpro
Default Led dome light
Who has done this, and what bulb did you go with?
Old Sep 16, 2009 | 03:27 AM
dakotas ram's Avatar
dakotas ram
dont remember, but i do believe that i just took my bulb to autozone and matched it up to a led one that was on the rack......if not, you can always go onto ebay and type in the bulb# then add led to the end of it.....will work for just about any bulb
Old Sep 16, 2009 | 04:36 AM
Sheriff420's Avatar
Sheriff420
just about any bulb eh? have you ever seen a ram with led corner bulbs dakota?
Old Sep 16, 2009 | 09:46 AM
pcfixerpro's Avatar
pcfixerpro
Sylvania says the bulb is a 579 bulb which is for some reason difficult for me to find. The other thing is it can't be a straight blub with led's on the end, it would have to be a 360 type or similar for a dome light like the regular bulb right?
My buddy just did the led conversion for his done and courtesy lights in his 08, and that made a huge difference. That is what got me interested.
Old Sep 16, 2009 | 09:58 AM
004x41500's Avatar
004x41500
just buy the pack of 4 prewired leds, use at least two of them in the dome light, thats how i did mine, and its actually pretty bright, though i might add 1 more led. all you really have to do with it is twist the ends of the wire together, and push it into where the bulb would go or you can crimp a spade terminal onto it and do it like that... ill have a right up with pics soon, just been busy with college, and work.
Old Sep 16, 2009 | 12:59 PM
dakotas ram
http://cgi.ebay.com/ebaymotors/2x-AM...Q5fAccessories
its easy, like i said.....went on autozone.com, found out it was a 3157 bulb and went to ebay and searched 3157 led and voila.......
Old Sep 16, 2009 | 01:05 PM
dakotas ram
heres pics of mine....not the brighteset since it is blue, but its bright enuff
Old Sep 16, 2009 | 01:08 PM
dakotas ram
heres a 579.....does no one believe me?
http://cgi.ebay.com/ebaymotors/2-Blu...Q5fAccessories
Old Sep 16, 2009 | 04:38 PM
004x41500's Avatar
004x41500
holy triple post. lol. i belive you, i just had 2 extra leds from when i started my dash, so i used em in the dome light rather than buyin more.
Old Sep 16, 2009 | 06:12 PM
pcfixerpro's Avatar
pcfixerpro
Thanks for the link, but I was hoping for something more directional. That is going to shoot all the light to one spot (and not at the direction of down.) The refracter is also above the bulb (again the linked light shoots towards passenger side) so that isn't any help either. I am thinking about trying my luck and fabricating something like this to work
http://superbrightleds.com/specs/WLED-xHP10-D.htm
From some quick measurements it looks like the light assembly will hit the refractor so I may need to do something with that. Also im not sure if the light end will fit in the socket correctly since it isn't ment for it. Guess ill do some homework...
