Leveling kit Questions.
Old Sep 19, 2009 | 02:39 PM
EHS22's Avatar
EHS22
Default Leveling kit Questions.
I have a 1997 Dodge 1500 4x4. Im wantin to put a Rough Country 2.5 levleing kit on it. Im concerned though. I have heard of something called a "death wobble" that happens with levleing kits where the truck wobbles and rolls over when your driving. I know nothing about it, but i have heard that if you put a Trac bar on the truck when you put the leveling kit on then it can prevent this? Im confused can someone explain this to me, and what kind of leveling kit would you recomend?
Thanks.
Old Sep 20, 2009 | 03:05 AM
helms's Avatar
helms
try searching "death wobble".
Old Sep 20, 2009 | 02:19 PM
Sheriff420's Avatar
Sheriff420
you already have a track bar.
with a leveling kit all you're doing is putting a spacer between the coil spring an the body.
the only ill effect to come out of a leveling kit is the front end will pop up in the air a little more when you have the bed loaded down.
hell bent steel (HBS) is the kit i'm going to go with when i level my truck.
as far as i know you can go up to 3" with the stock shocks, but i'm going to do a 2.5" level just to be sure that my shocks won't pop.
Old Sep 20, 2009 | 03:01 PM
Miami_Son's Avatar
Miami_Son
Do a search for "Hell Bent" as there's a very informative thread already here on it.
Old Sep 20, 2009 | 03:10 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Death wobble is not cause for that. If it was all these guy with huge lifts would not be able to drive anywhere. I have had it its not fun.
