auto trans to manual trans swap
Old Sep 20, 2009 | 09:59 PM
96dodgeram360's Avatar
96dodgeram360
Default auto trans to manual trans swap
I got a 96 dodge ram 360 and i want a manual transmission but im stuck with an auto so is there somewhere out there like possibly a convertion kit or is a junk yard my best option, cause i can buy NV3500 transmissions all day long but i need a little more than just the trans any help would be nice thanks
Old Sep 20, 2009 | 10:21 PM
olyelr's Avatar
olyelr
Yeah, your best bet is to have a donor truck, so you can get all the parts that go with it (clutch pedal assembly/linkages etc.). Also, from what I understand you will have to get a different flywheel as well, as the they are balanced differently, and you will have to have the PCM flashed too.
Good luck with the project... its been a dream of mine for years.
Old Sep 20, 2009 | 10:23 PM
SpcD1500's Avatar
SpcD1500
donor truck would be the easiest, then just replace any broken and/ or worn out parts you may need. IIRC 1500's diddnt come with a 360 and a stanard, youll have to get a 2500
Old Sep 21, 2009 | 09:58 PM
96dodgeram360
ya looks like its a automatic over haul for me but.... i found a good wepsite that has alot of really strong trans kits (so i have heard) here is the link http://www.transmissioncenter.net/dodge.htm they have alot of viper transmission parts for our type transmissions check it out... there is a guy in my neibor hood that claims he can overhaul automatics so ima talk to him see what he can do
Old Sep 22, 2009 | 09:27 AM
olyelr's Avatar
olyelr
Yep, the RAMZILLA is the one you want $$$$$$$$$$$!!!!!!!!!!!!!!!
