Buyers Remorse....Help with 96 Ram PLEASE
Old Sep 22, 2009 | 09:43 AM
Nhxj4x4's Avatar
Nhxj4x4
Originally Posted by Augiedoggy
as long as the body and frame aren't rotted I dont think 2 grand is bad for a running 4wd truck....you have to expect its going to need work....I know prices are different in different areas but here they rot out fast and 4wd's hold a premium thanks to our fun buffalo winters....
I agree, the frame is in good shape. I'm in NH so I certainly know about rot, and the only rotted part is the rocker panels. I found those for $140 shipped for the pair so not bad there. My concern is making this a SAFE, fun truck for my family. As it sits now, my dog isn't allowed in there. I plan to spend the better part of this weekend working on it.
Old Sep 22, 2009 | 01:28 PM
Nhxj4x4's Avatar
Nhxj4x4
I talked to PA this afternoon about the lift. They I can get the weld in parts seperately if I need them.
Does anyone know if this problem with the linkage can indeed make me lose D but still have 1 and 2? How many gears is the 1500, I assume 3 + OD?
Thanks,
Todd
Old Sep 22, 2009 | 01:40 PM
dodgerules86's Avatar
dodgerules86
I wouldn't *think* the linkage alone would make you loose (D) but still keep gears 1 and 2.
Since (D) comes first in the sequence (PRND21, as you know).
And yes, the transmission would be a 4 speed (3 regular + electronically activated overdrive)
Old Sep 22, 2009 | 03:08 PM
Nhxj4x4's Avatar
Nhxj4x4
So I could indeed still be fooked....lovely. We'll see.
Old Sep 22, 2009 | 03:13 PM
Ram1500Dodge's Avatar
Ram1500Dodge
have you infact lost "D", if you drive it, where are the RPMs at? When i put my body lift on my 97, I had to weld in the extension rod that allowed the lever to be positioned properly. I had the same problem as you until I realized that I had to weld in the extension. Also, again, I had the same setup, with the 35 inch tires, a blown plenum, and the 3.55 gears, you aren't going anywhere in a hurry.
Old Sep 22, 2009 | 03:38 PM
Nhxj4x4's Avatar
Nhxj4x4
Well it doesn't shift, I know that. I can be doing 40 and floor it and there is no shifting that takes place. I tried it at all speeds, uphill, etc. RPMs on the way home not exceeding 60mph were around 2400-2600 which isn't bad considering the tire size, but again, going up a very steep hill it didn't downshift. I can't feel any upshifting either. Turning OD Off does nothing either, usually you would see/ feel an uptick in the RPM's.
Someone please explain the Plenum thing. Would that cause kinda a sputtering under load? She rev's like a SOB, but once in gears she's kinda hesitant a bit.
I hate 3.55's. I have 4.56's in my Cherokee on 35's, damn 3.55's.
Old Sep 22, 2009 | 03:45 PM
Ram1500Dodge
try driving in the presummed 2nd gear and barely tapping the gear selecter up and see if it changes, sounds more like a linkage problem due to the body lift. do a search for the plenum gasket problem, much easier that way. turning OD off if your in 2nd gear isnt going to do anything because you haven't reached "drive" yet.
Old Sep 22, 2009 | 03:54 PM
Nhxj4x4's Avatar
Nhxj4x4
I will give that a shot on both accounts... Thanks everyone, certainly enjoying the pace of this forum!
Todd
Old Sep 22, 2009 | 03:58 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Where in NH do you live? Send me a PM if you want that private. I live in NH as well.
Old Sep 22, 2009 | 05:10 PM
Nhxj4x4's Avatar
Nhxj4x4
I'm in the Keene Area man, Mt. Monadnock is in my views. How about you?
