Running without a cat converter
Old Sep 24, 2009 | 04:22 PM
Bamadodge13's Avatar
Bamadodge13
Default Running without a cat converter
I took out my converter and put true duals with flow 40 series....only 2 mufflers no converter...i was hopeing the o2 sensor wouldnt throw a code and about a week later it did....(code number po420 catalyst efficiency) and i was wonderin if anyone knew a way around this...i would really appreciate your imput...thankyou
Old Sep 24, 2009 | 04:28 PM
jasonw's Avatar
jasonw
Site Moderator
If he still makes them:
http://www.thefastman.com/02Simms.asp
Otherwise, some of the slightly older Rams you could weld a small extension onto the O2 sensor port, and screw the sensor into the extension. The extension would have the sensor be out of the exhaust stream. I don't see why that wouldn't work for our newer 2001s.
Old Sep 24, 2009 | 04:32 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Spark non foulers will work for extending them
Old Sep 24, 2009 | 04:34 PM
sanford35_5.9's Avatar
sanford35_5.9
I took my cat out and only pluged the front O2 sensor in on my truck and just took out the sencond completely out. It will run the truck off the second O2 sensor memory and just throw a volts to high or low code and still run the truck just fine. If you leave the second one in and it gets a bad reading then it will throw that code you have and make the truck run poor.
Old Sep 24, 2009 | 09:14 PM
jasonw's Avatar
jasonw
Site Moderator
sanford35 is correct. If the first, before the cat, O2 sensor is still plugged in, your truck will run fine.
The second O2 sensor, post-cat, has nothing to do with how the truck runs. All it does is tell the computer if the cat is working properly or not, and if it isn't pops a code saying it isn't. Personally, that yellow CEL on all the time would bug the crap out of me, but its up to you.
Not to mention you would have to check codes periodically, as you have the CEL on for that post-cat O2 sensor on all the time, you can't tell when another code pops up unless you scan it regularly.
Old Sep 24, 2009 | 09:53 PM
jbomb's Avatar
jbomb
fastman still makes them. Talked to him today about mine as well as my 53mm tb I will be getting this weekend!
Old Sep 24, 2009 | 10:39 PM
lastrights's Avatar
lastrights
im planning on doing 2 cats no mufflers you could try that with and x pipe
Old Sep 25, 2009 | 01:03 AM
dakotas ram's Avatar
dakotas ram
yeah, just get 2 17mm sparkplug nonfoulers as posted^, screw one of them in the 02 bung and take the 2nd and cut it so the sensor will screw into it the screw it to the other one
Old Sep 25, 2009 | 06:08 AM
wjxavier's Avatar
wjxavier
or you could get a x or H-pipe and drill a hole right where the two pipes meet...weld in a o2 bung and you're good to go.
Old Sep 25, 2009 | 10:07 AM
dakotas ram
thats what i did with my exhaust
