Speedo Problem
Old Sep 26, 2009 | 10:24 PM
mjackson92rs's Avatar
mjackson92rs
Default Speedo Problem
speedometer cuts in and out while driving. my question is what sensor sends the speed signal to the speedometer (assuming its electric)? and where is it located?
Old Sep 26, 2009 | 10:43 PM
greenmachine's Avatar
greenmachine
99 and earlier have the speed sensor in the tailshaft of the transmission. When I had my 99 I had to clean all the metal shavings off and it was fine.
Old Sep 27, 2009 | 01:26 AM
mjackson92rs
thanks a lot. how easy is it to pull out? easy to get to?
Old Sep 28, 2009 | 05:59 PM
mjackson92rs
bump.
Old Sep 28, 2009 | 06:05 PM
intense00's Avatar
intense00
used to have a 97 dakota, and the speedo and tach sometimes wouldint work unless you tapped on the plastic. musta been a loose connection in the dash on mine.
Old Sep 28, 2009 | 06:14 PM
greenmachine
single bolt with bracket located on drivers side. be ready to stuff a rag in the hole until you are ready to reinstall.
Old Sep 28, 2009 | 08:12 PM
dhvaughan's Avatar
dhvaughan
auto trans speed sensor on my 01 4wd is on passenger side, at the rear of the t-case. not much fluid comes out - less than a cup and just enough to make a little mess if your not sort of ready for the swap.
Old Sep 28, 2009 | 09:47 PM
greenmachine
Yea missed the 4 wheel drive part.
Old Sep 29, 2009 | 07:30 AM
dhvaughan's Avatar
dhvaughan
i'm not familiar with the sensor setup on your 95, but the later models also have a speed sensor/abs sensor in the top of the rear diff. the official name of it on most parts lookups are rear abs sensor. its sort of square shaped and sells for about $30. it also has interaction with the speedo. the one in the trans/t-case is cheaper, only about $16.
Old Sep 29, 2009 | 11:29 PM
Sickboy74's Avatar
Sickboy74
Ok guys now I'm lost the local dealer told me my 98 only had the speed sensor in the rear diff now I'm on my third one and still no speedo are you sure I have one on the Tcase because I haven't found it.
