Best Gears to buy?
Old Sep 29, 2009 | 11:33 PM
big.red.ram's Avatar
big.red.ram
ok and get the carrier from randys?
Old Sep 29, 2009 | 11:40 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Yes. Make sure you get one that is 3.92 and up.
big.red.ram
and one more thing...will i need to use a different weight gear lube since im changing the gears? or will it matter
Old Sep 29, 2009 | 11:41 PM
big.red.ram
ok thanks alot!! been a huge help
Old Sep 29, 2009 | 11:43 PM
big.red.ram
sorry one more thing actually lol on the completeoffroad site it says dana 44 standard and dana 44 disconnect. which one do i need?
Old Sep 30, 2009 | 12:24 AM
dodge15004x45.9
I would think you can use the same gear oil weight. I'm not sure on your 2nd question.
Old Sep 30, 2009 | 01:02 AM
Hahns5.2's Avatar
Hahns5.2
I like Yukons...
Old Sep 30, 2009 | 11:29 AM
big.red.ram
i stopped by a local repair shop and they said it would be around 5 or $600 to install the new gears if i supply the gears...sound right to u guys?
Old Sep 30, 2009 | 10:20 PM
Rockyhigh360's Avatar
Rockyhigh360
Sounds good... make sure you break in your gears properly. Also, see if they provide a warranty on install up to 30 days, just in case they screw up the shims. After a few weeks pop the covers off and check your fluid and ring gear for any uneven wear. Good luck, and nice truck
Old Sep 30, 2009 | 10:50 PM
dodge15004x45.9
Just to add to the guys above me, change the gear oil after 500 and 1,000 miles. Clean all metal out! Get a magnet installed in there so it will get stuck to that and not all over the place.
