rear wheel cylinder
Old Oct 1, 2009 | 05:45 PM
rollinlow's Avatar
rollinlow
Default rear wheel cylinder
am I missing something on this thing guys, I dont have pics but i have put two pass side rear wheel cylinders on in the last two days put new pads on and all the springs are in by the manual, would the drums be that thin that it lets the cylinder comp expand?
Old Oct 1, 2009 | 06:32 PM
J415's Avatar
J415
did you adjust the adjustment screw at the bottom?
Old Oct 1, 2009 | 07:03 PM
rollinlow's Avatar
rollinlow
yes i did til i felt just a little drag in them
Old Oct 1, 2009 | 07:15 PM
dhvaughan's Avatar
dhvaughan
drum thickness shouldn't really have anything to do with it. they couldn't wear more than 1/4" at the extreme most.
try this. open up the master cyl and lower the fluid level a little. compress the cylinders all the way in. some fluid should move to the master cyl. extend the brake adjuster a little more and reinstall drums. DONT mash the brakes yet. extend the adjuster through the backing plate until the brake locks up. then loosen it until it turns freely with just a hint of drag. you may still hear a tick, that's ok. do both sides. now bleed brakes.
Old Oct 1, 2009 | 07:23 PM
rollinlow's Avatar
rollinlow
ok ill try that does any one else have any suggestions? at ten bucks a pop replacing wheel cylinders is getting old
Old Oct 2, 2009 | 01:44 PM
rollinlow's Avatar
rollinlow
thanks dhvaughan just put another new one on and adjusted them and as of right now with 70 miles on it and bout 20 min in a mud hole no leaks and it stops much better to boot
