Charging problem
Old Nov 28, 2009 | 03:40 PM
  #31
nathangfnd's Avatar
nathangfnd
Default Battery or alternator voltage is to low???But wont go up
I installed a new intake manifold and after the install the check gauges light comes on and the battery or alternator voltage is to low.
It stays at a constant 10 volts, it wont go up or down so im not sure what the problem is.
Is it part of having new hughes FI intake manifold or should it stay the same, I say stay the same but i dunno
Why would it do this and has it ever happened to you
(Battery is a optima red top and 6 months old, alternator is a stock replacement put in same time as battery)
Old Nov 28, 2009 | 03:52 PM
  #32
dhvaughan's Avatar
dhvaughan
intake manifold should not affect electrical system. check your electrical connector and wiring around the alternator. sounds like its unplugged or damaged.
also check fuses in both the end of dash and in the pdc box.
Old Nov 28, 2009 | 04:00 PM
  #33
ET RAM's Avatar
ET RAM
Test the voltage at the battery with engine off. It should read around 12 volts depending on battery condition. Now, start the engine and check battery voltage again. It should read 13-15 volts if the alternator is charging.
If you do not read 13-15 volts check the alternator output. Connect volt meter red lead to large terminal on alternator B+ and black lead to ground. With engine running you should see the charging voltage listed above.
If alternator is charging but battery is not getting charged, check the fuses in the PDC.
Old Nov 28, 2009 | 04:08 PM
  #34
95RAM360's Avatar
95RAM360
its not a good way, but a way to test the alt. is with truck running take off the negitive terminal on the battery, if truck stays running, the alt. is ok, if it dies its bad, but if it keeps running you may have a dead cell in the battery.
Old Nov 28, 2009 | 06:38 PM
  #35
xray99's Avatar
xray99
Voltage regulation is unfortunately controlled through the ECM - So if you determine that the ALT is putting out voltage but its not reaching the BATT, check this
https://dodgeforum.com/forum/2nd-gen...g-problem.html
BTW, a properly charged BATT should read 12v with engine off, around 14v running.
Old Nov 28, 2009 | 07:26 PM
  #36
juanbosco's Avatar
juanbosco
Thanks xray99!!
I think that it is an Borg Warner R296 Voltage Regulator:
http://www.amazon.com/Borg-Warner-R2...9453502&sr=8-3
I will wait for your more detailled information... And if you could, some wiring diagram...
1000 Thanks again xray99!!
Old Nov 28, 2009 | 09:40 PM
  #37
xray99's Avatar
xray99
Did I just supply a link to the same thread ?
Sheesh, must be getting mixed up here.
Anyhow I'll post more detailed info as I get it, first step would be to see if your ALTS also have green n blue wires coming off the back.
That BW is it, not sure if the extra $20 is worth it or not, to get the name brand.
Old Nov 28, 2009 | 10:28 PM
  #38
nathangfnd's Avatar
nathangfnd
Well boy I got her fixed. I connected wrong wire to alternator because the one for iat sensor and alt are the same basically. Sucked cuz truck died on me and I left my phone at home. Sorry if this comes out weird I'm on my phone
Old Nov 28, 2009 | 10:41 PM
  #39
xray99's Avatar
xray99
Glad you found the problem, usually its hard to botch the wiring of an ALT because they will only wire up in certain ways, but it can happen.
Lucky you didn't fry anything out.
Old Nov 29, 2009 | 12:02 AM
  #40
nathangfnd's Avatar
nathangfnd
yeah. i dont know how i got them mixed up but i did.
The connectors are almost exact size. The one for the ALT is a little smaller which is why i had an issue plugging in the IAT sensor, i couldnt fully get it on but i figured i may have crushed it a little
