Washer-pump went out today,..
Old Oct 6, 2009 | 09:01 AM
JBs DAK's Avatar
JBs DAK
Question Washer-pump went out today,..
Checked plug with a test light, it came on when I depressed the washer lever so,
it leads me to think the pump has gone south. (Also didn't hear it either).
It turns real easy at the bottom of the resevoir but I didn't want to start tugging on it trying to pull it out if something is gonna break! How do I get the thing out!!??
Also, does pat-stores carry replacements or is it Stealership only?
'96 4x4 ext-cab 360. Thanks for any info,.. Tried search function with no luck.
Old Oct 7, 2009 | 05:16 AM
JBs DAK's Avatar
JBs DAK
Well, I got it out,.. I 1st pulled the rubber fluid line off
and let all the washer fluid drain into a pan. then pulled
the electrical plug.
It is held in with a rubber grommet.
I pulled and twisted at the same time and out it came.
Replacement at Advance-Auto was 17 bucks. Easier than I
thought it would be. The old one was way rusted on the
little motor case.
Old Oct 7, 2009 | 09:27 AM
charlie1935's Avatar
charlie1935
Thumbs up
Thanks for posting the fix.
