Attempting D.S. Axle Seal...
Old Oct 11, 2009 | 09:19 PM
95RAM360's Avatar
95RAM360
Default Attempting D.S. Axle Seal...
ok so tomorrow i am going to attempt my axle seal on the drivers side. Now i have read the write up on how to do it, and it doesnt mention having to take out the pass. side axle, now cn i take the gears out of the pumpkin, and take only the drivers shaft out? or do i need to do pass?
Also what special tools am i going to need for this? like howto take out shaft and gears. Is there a certain way to take gears out and put in?
Please and feedback will help
I also have the Haynes repair manual, but it shows how to do both sides. i only want to do the one
Old Oct 12, 2009 | 09:10 AM
95RAM360's Avatar
95RAM360
bump...
Old Oct 12, 2009 | 10:17 AM
Sheriff420's Avatar
Sheriff420
http://www.pavementsucks.com/tech-article-5.html
http://www.pavementsucks.com/tech-article-3.html
when i changed mine i used a come along attached to my dads hitch to pull the carrier out. i wrapped a small chain around the carrier and had my dads truck backed up to mine lined up with my front diff. i had him slowly cranking on the come along while i was under the truck to catch the carrier.
you do need to take the passenger axle, intermediate shaft and the cad unit off to get the carrier out.
i disconnected the driver side tie rod because i needed to change the boot anyway but it was nice not having it in front of the diff when i removed the carrier.
measure from the seal to the outside of the axle tube or from the seal to the inside of the axle tube because there isn't a stop for the seal so it would be easy to drive it too far.
you need:
a high quality penetrating fluid for the hub bolts/nut
14mm 12point socket
3/4" drive breaker bar with about a 3 foot piece of pipe for a cheater bar
1 11/16" socket for the breaker bar
1/2" to 3/4" adapter for when you put the nut back on
seal driver (1 3/4" socket will work)
1/2" drive torque wrench that will go over 175 ft-lbs
21mm socket for the caliper mounting brackets
a piece of rope to hang the calipers
dead blow hammer
pry bars or a come along
rtv sealant
new gear oil
drain pan
anti-seize
rags
jack stands
patience.
Old Oct 12, 2009 | 10:33 AM
95RAM360's Avatar
95RAM360
nice i havent seen that write up. got all the info i need, except how long do you think this takes?
thx for the good info
Old Oct 12, 2009 | 11:25 AM
Sheriff420's Avatar
Sheriff420
it took me a couple weeks because i'm lazy and i had to go back to the parts store a time or two, but i'm sure that if you have everything you need to start off with then you could get it done in 6 hours or less + the curing time for the rtv. so do it on a saturday and it'll be done by sunday.
i wasn't in a hurry to get mine done because i have my camaro to drive when the truck is torn down. that and i don't have anyone to help me when it comes time to work on my truck.
Old Oct 12, 2009 | 12:14 PM
95RAM360's Avatar
95RAM360
yea i think im gunna start it, i got 2 spare vehicles just in case so im not worried about how long its gunna take, just wanted to get a rough idea.
