Oil Light Flickers
Old Oct 16, 2009 | 07:32 AM
Iamamammal's Avatar
Iamamammal
Default Oil Light Flickers
Was wondering what this might mean, some times my oil light will flicker while I'm at idle or in park. Usually happens when I have the brake on, but not always. Oil is not low or dirty. Tranny fluid is not old or dirty. Brake fluid, same deal.
I'm thinking it might be electrical? I have intermittent issues with headlights turning on/off usually when I'm driving at night.
Old Oct 16, 2009 | 08:34 AM
halfamil's Avatar
halfamil
Usually means low oil pressure.Headlight switch is going out..HL switch is an easy fix.
Old Oct 16, 2009 | 08:52 AM
Sheriff420's Avatar
Sheriff420
your headlights might be loose plugs on the bulbs if not the switch. turn them on then grab each plug and wiggle it a little bit. one of mine was loose a couple months ago and it would dim for a few minutes off and on.
Old Oct 16, 2009 | 09:39 AM
95RAM360's Avatar
95RAM360
whats the oil pressure runnng at?
