Wild Vents question
Old Oct 18, 2009 | 12:02 PM
Pyromanaron's Avatar
Pyromanaron
Default Wild Vents question
I tried to do a search but nothing came up. I remember reading on this forum that "somewhere" in the dash is a vacuum connector, or connectors, that can screw up the A/C, and cause a vacuum leak. Has anyone ever done a write-up or fixed this problem before? I've checked all the vacuum connectors under the hood and they're all good. I have a vac leak somewhere in my A/C system and can't pin it down.
Old Oct 18, 2009 | 02:25 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The check valves may be bad (black round things inline with those hoses you checked under the hood), and if you have cruise control there is a hose and CC module under the battery tray you need to look at.
Old Oct 18, 2009 | 02:50 PM
zman17's Avatar
zman17
You might also want to check the hoses going to the 4x4 shift motor on the back of the passenger side front axle. And here is a good thread about the check valves https://dodgeforum.com/forum/2nd-gen...ild-vents.html
Old Oct 18, 2009 | 03:27 PM
Sheriff420's Avatar
Sheriff420
don't miss post # 28, 31, 39 and 55.
