Low/rough idle, intermitent
Old Dec 20, 2009 | 09:26 PM
  #21
004x41500's Avatar
004x41500
Originally Posted by Trey318
Tried some WD-40 on the vac lines to see if I could get it to rev a little, and the idle stayed consistent. I bled the fuel lines not too long ago when my dad used his injector cleaner. I pretty much had to because I got one hell of a shake, but this isn't like that.
wd-40 wont cause the motor to rev. use i would use starting fluid, and that would yield the best results that i know of.
maybe chris will chime in here. but for the time being i would use starting fluid.
Old Dec 21, 2009 | 12:23 AM
  #22
cmckenna's Avatar
cmckenna
Most use propane to check for vac leaks but, only at the intake. If and when checking the lines, use a vac pump and pump down a section at a time and note if it's holding vac or not.
Common areas to check first are your brake booster diaphragm. Remove the hose and pump it down. See if it holds. If not, there's your leak. Then, remove the main line coming off the TB and pump vac. If it holds, all lines are fine. If not, proceed to tracing out which one/s are leaking.
In the rear of the manifold, there's a feed that goes down behind the motor that feeds the tranny. Remove this line from the T-fitting and apply vac. Note if it holds or not. If not, there's a hole, leak in that line. It even may be at the tranny. At the time of hitting something in the road, it has been reported to eject the connection off of the vac port on the tranny thus causing a huge vac leak.
There's not too many to go through so, it's not so bad as it may sound initially. Just remove one section at a time and pull vac on it. If none are found to leak, then I would start checking at the intake level. Work from the top down. Start with the Air Intake to IAC, then to the TB gasket then at the ports, at the injector o-rings, check the side gasket areas that mate up to the heads, to finally a blown plenum gasket.
On the IAC, there's a rubber seal that, if it's not seated correctly, it will leak on you creating a loud hiss. Remove it and check for a dimpled rubber o-ring seal. If it's dimpled or crushed, it needs to be replaced. Check to make sure it's not ****-eyed in the TB. This is another area prone to leaks.
Old Dec 1, 2011 | 10:33 AM
  #23
pjhoecherl's Avatar
pjhoecherl
Originally Posted by oiler
My dads 00' 5.2 5 speed has a idle problem that comes and goes hot or cold. The air cleaner will also become very loud like it is pulling massive amounts of air. Then out of no where it will pick up and idle good and the noise goes away. The plenum has been repaired and the Iac and TPS hane been replaced. Any ideas? The truck has about 130k on it.
I just had a major problem with this, the good thing is that its not all the time or it would be a plenum gasket leak.or throttle body. So you may not get a code or maybe misfires or running rich. The IAC is the culprit. plugged in behind your throttle body. 2 #5 torx screws and a plug. o-ring gasket. if its corroded it may be binding hence intermittent. after replacing the map tps and plugs wires all that and the IAC it came back to the IAC as it was defective out of the box. Now replacing it is best, pull the negative battery terminal while you take a rag saturated with carb cleaner and clean the port the Iac was removed from, not the Iac .replace it and reconnect the battery, then drive about 40 mph so the computer can relearn the Idle position. if this doesnt work look inside your throttle body through the ports with a flashlight at the bottom will be the plenum. some carbon is OK if it looks wet with oil the plenum gasket is leaking. I hope this was helpful..
Old Dec 1, 2011 | 10:56 AM
  #24
UnregisteredUser's Avatar
UnregisteredUser
Replying to a two year old thread? And with your first post ever?
Welcome to DF anyway.
